I'm trying to install a new thermostat that needs a C wire hookup. There are currently 4 wires running from the thermostat to the furnace, none of them are a c wire. When I look at my furnace itself it has a spot to put a c wire but it's currently being used by my whole-home humidifier.
If I run a separate 18-1 wire from my thermostat to the furnace can I just wire both the humidifier and thermostat to the one c-wire hookup?
gregmac
  • 29,300
  • 89
  • 162
Paul Lemke
  • 285
I also have a thermostat that requires a C wire hookup for wifi access. The spec calls for a 24 volt DC and I presently have it wired to share a 24 volt termination on my AC air handler. What I discovered was that this termination in the air handler does not provide a constant output of 24 volts. Instead, it cycles as called upon by the air handler and the thermostat would run until the battery failed which took about a month. Plus I could not get the wifi to properly pair with the thermostat due to the cycling of voltage on and off to my C wire termination at the thermostat.
This afternoon I have an electrician coming to give me a dedicated wire from a 24 volt transformer for my C terminal. I expect this to solve my problem.
So based on my experience, be cautious of sharing unless you know the source will provide constant power.
bg2011
  • 166
You can have multiple devices utilizing the C terminal at your furnace.
Steven
  • 27,770
  • 56
  • 90
