Some months after I turned this saddle valve off I turned it back on. It leaked with increasing flow until it was completely turned on. Then it stopped. Is this ok? Is it normal? Or would I be wise to replace/repair the valve.
Asked
Active
Viewed 1,208 times
Saddle valves are notorious for leaking and failing in just a few years. The best repair would be to install a T at the point the saddle valve is attached. This is something most DIY folks can do with plastic or copper pipe a bit more difficult if galvinised pipe. If you stay with a saddle valve get the best quality one you can find.
Ed Beal
- 103,727
- 4
- 79
- 158
Is this OK?
No, you should replace the valve as soon as you have the chance, better yet would be to install a tee and regular stop-valve, preferably one of high quality.
Is it normal?
It is fairly common for older valves to leak at the stem area until back-seated (or as you said, completely turned on).
Jimmy Fix-it
- 37,916
- 35
- 62
