We just had a carpet layer come in for measurements and a quote. We've not put in the baseboard or door casings yet, but the carpet layer has suggested that this will make things easier.
Is this true / good advice? Are there any pitfalls to watch for when we go to install the door casings / baseboard?
Aarthi
  • 1,143
Noah Goodrich
  • 722
6 Answers6
It makes it easier for the carpet installer because they don't have the baseboards in the way when they're nailing in the tack strips next to the wall.
On the other hand, it makes things a little more difficult to install the baseboard later because the carpet and tack strips are in the way when you're trying to nail the baseboard to the sole plate in the wall. This is much more of an issue if you're nailing by hand than if you're using a brad nailer. (I've done it both ways; use a nailer.) If you're doing a long wall, it can make lining up the pieces of baseboard a little trickier because the tack strip and carpet can get in the way.
On the whole though, I'd follow his advice and use a nailer to install the trim.
  • 20,909
  • 95
  • 135
My two cents worth..... We always install the base trim and door trim first. If you have split jam doors with the casings already attached, you must install them first or you will have a real problem fitting the jams to the floor between rooms. As mentioned, sometimes the carpet installers can scratch the finish on the baseboards, however it is usually minor and easy to touch up after. The problem I see with putting the trim on last is that depending on the style and thickness of the carpet and pad, you can have a bit of a ridge over the tack strip. Of course you can nestle the trim down into the carpet, but some of the bottom square edge of your trim may still show. It is also much more difficult to maintain a level line and make splices on longer runs. If the corners are not perfectly aligned, then coping the base won't match properly. Since the trim should outlast the carpet, anytime you need to re-stretch the carpet or remove it, the trim will have to be removed first as it is impossible to do either with the trim in place. Now that is an absolute nightmare and rarely will you be able to salvage all the trim to re-install.
My advise, install the trim and doors first and stress to the carpet installers to be as careful as possible. You can also put a strip of 2 inch delicate work painter's tape on your trim before the carpet goes down. Leave about a half inch at the bottom of the trim uncovered, then remove it after the carpet is installed. This will help prevent some of the minor scratches the edge of the carpet can cause before it is chiseled behind the tack strip.
shirlock homes
  • 58,628
  • 87
  • 168
I worked many years for a new contruction house painting company and the proper way is to install trim before carpeting. It's how the pros do it it. Amateur house flippers I'm sure won't agree....or the guy you hire to replace your trim that's looking for a fast buck; he'll tell you what he wants you to hear. Beware.
Kye Gunn
the baseboard goes in first always, the carpet installers don't like this if they have to install new thicker baseboard for the customer, they have to remove the old tack and install new, this is very time consuming and their usually on piece work. In my house they had to go from carpet to tile and lino. Putting base on top of carpet then to tile would not work, plus changing carpet later would mean new baseboard also
Roger
If you put the baseboard/casings in first, the carpet has to be fit around them. And in my experience, the carpet installers will damage the baseboards as they stretch the carpet.
If you wait until the carpet is installed, your baseboards can go in on top of the carpet, which will help keep the carpet in place (not usually a problem but hey...) but at the same time make removing the carpet more difficult (but not much so) in the future.
I cannot say there's a specific right way to do it.
The Evil Greebo
  • 25,971
  • 91
  • 125
It is mandatory in the state of New Hampshire to do it this way (Baseboard Installed First). Rev. NH BC Code 92.18-889.
mark f
  • 2,323
