27
I have some wood left over from building a patio, mainly some planks. Normally when I'm creating firewood, I just use an axe a split the wood, but these are too long for that. I really don't want to try and cut them with a wood saw or an Axe. The only tools I can think that make sense are a Jig Saw or a chain saw.
So what I'll probably do is cut them down with the jig Saw (and maybe split them with the axe)
What other alternative are there? Should be something hand held, I don't think a band saw or a circular saw would make sense.
  • 20,909
  • 95
  • 135
AidanO
  • 403
Reciprocating Saw
Most fun.
reciprocating saw.
Miter Saw
Fastest.
miter saw.
Circular Saw
Most likely to have on hand.
circular saw.
Jig Saw
Slow.
jig saw.
Hand Saw
Slower.
hand saw.
Butter knife
Slowest.
butter knife.
Pruning Saw
Longest reach.
pruning saw.
Fire
Cut right to the chase
fire.
Beaver
Requires lots of training, food, and cleanup (thanks @SteveJackson for pointing this method out).
beaver. member of the Rodentia family of mammals
Chain saw
By popular demand (don't use on PT wood)
chain saw.
No affinity to Ridgid, just the first brand in the list when searching for reciprocating saw.
Depending on how much left over wood you have, you may consider checking to see if your community has a building supply recycling center. I live in a relatively small town and we have a non-profit organization here that takes donations of left over building supplies and used (but usable) materials that have been removed as part of a remodel (faucets, doors, etc). I'd be surprised if there aren't similar organizations all over the country.
Jon Garvin
  • 449
Bow Saw
A bow saw is a hand saw that's designed for cutting through branches and other fairly light outdoor tasks, where a chainsaw would be overkill. The teeth are much deeper than those on a typical woodworking-oriented crosscut saw (so they cut faster), and shaped to cut on both the push and pull stroke (so they cut even faster). Also, the blade is much narrower, so it is less likely to bind when cutting wood that isn't necessarily well-supported or clamped in place. A good bow saw can cut through sticky, sappy, green branches in seconds, so seasoned lumber will be no problem.
Adam Jaskiewicz
  • 1,121
A reciprocating saw (sawzall) is perfect for this job. Get the right blade, one that can handle an occasional nail if there is one, or use a pure wood cutting blade if that is not a worry. These saws will cut through anything. In fact, I once used one in lieu of a chain saw for a huge amount of fallen wood after an ice storm.
My second choice is a small, hand held circular saw, the battery driven kind. Small, easy to maneuver. You can cut a surprising amount of wood on a charge with one of these. Use a good carbide blade.
Third choice is a hand saw. If sharp, they can do a lot of work, and get your heart going - a good thing. Ok, maybe this should have been the first choice.
