In the UK, we use water radiator systems when the boiler heats the water to about 70°C, this allows the boiler to get most of the energy out of the gas (or oil) by condensing the steam you get from burning gas.
I can’t understand why anyone would design a system that could not operate with a condensing boiler – what am I missing?
Jeff Ferland
  • 2,688
Walker
  • 6,275
  • 66
  • 87
The US has a mixture of systems. I'm not sure what the prevalence is, but I've lived in homes with both steam and hot water heating.
Steam offers the following advantages:
  • One-pipe systems
  • More heat transfer for a given radiator surface
  • No distribution pumps
Steam offers the following drawbacks:
  • Furnace needs to be a low point
  • Corrosion
  • Finicky distribution
Modern installations tend to favor hot water. The New England region has a legacy of steam heat that stems from coal furnaces and basements. Those systems were selected a century ago, and refit would require replacing the entire system. Steam was the leading technology in New England during its greatest period of growth.
Further, New York City had a substantial influence in the area with its district steam heat operations. Also, another good article that discusses steam legacy, why replacement is a bear, and how steam works in general.
Finally, in large distribution environments, there's the high pressure factor. If you need to move a lot of heat energy, you can do so space-efficiently with high pressure steam (smaller pipes). Harvard's Blackstone Steam Plant heats over 160 buildings and drives a 5 megawatt turbine. At larger scales like this, the thermal loss at the chimney is far lower than the combined loss that would be had from running at sub-boiling temperatures.
Jeff Ferland
  • 2,688
