I'm trying to understand a bit about nuisance-tripping, and I'm wondering if anyone here has some insight.
I know (or think I know) that a Class A GFCI breaker should trip when there is a 6mA ground current (fault). I've also read that an AFCI breaker will generally trip when there is a 30mA ground current.
So my question is: are nuisance trips more likely on a GFCI due to that lower threshold (6mA), compared to AFCI (30mA)?
I apologize if my terminology isn't correct. I think I know what I'm asking, but... maybe not.
People seem to indicate that you should never use GFCI protection on your refrigerator due to the possibility of nuisance trips. But AFCI protection is required. I'm assuming the AFCI is less likely to nuisance-trip, and maybe this 6mA-to-30mA comparison explains why? The 30mA is low enough to mitigate fire risk, but high enough that most nuisance trips are avoided? (Whereas with a GFCI, the 6mA threshold is low enough to mitigate most risk of shock injury, but makes it more susceptible to nuisance trips?)
PhilPDX
  • 409
0 Answers0
