I hung drywall ceiling in my basement. I got impatient/lazy and decided to "finish" the project already by painting it with Kilz PVA Drywall Primer, even if the mudding & taping is not perfect yet.
I would say some taped joints need one more layer of mud & light sanding to be completely hidden (especially the outside corners with the CGC Perfect 90 tape (If I used normal folded paper tape, It would've shown less).
I haven't painted it with Latex. The primer is white and flat, which I think looks OK for now.
Should I decide to "fix" it, can I mud over the PVA primer?
Rollo R
  • 1,026
You can absolutely mud over cured primer. (Or cured finish paint, for that matter.)
Use all purpose mud (not a setting compound) and scuff the primer gently with 120 grit.
Aloysius Defenestrate
  • 23,521
  • 61
-2
Polyvinyl acetate dissolves in water and the mud is water based too. There is a possibility of the mud detaching and falling off. (Happens all the time) I would recommend sealing in the primer with a waterproof latex with texture. The texture will help the mud adhere better.
-2
Kilz PVA Drywall Primer is a product to be sold to amateurs that have no clue how drywall should be finished. It is not a cure all. The product can be utilized by spraying it on preexisting drywall to ensure the compound adheres the wallboard. Exp. if one wants to remove a textured ceiling and wants to apply joint compound afterward I would suggest using it to insure the compound adheres to the wallboard instead of "flaking" after the paint prime coat has been applied.
