I think I used the wrong concrete mix. It had rocks in it so when I tried to get it level, but I really struggled.
I then went and bought some self leveling cement to try to balance everything out. It looks better but it is not flawless.
I whitewashed it to give it a white look because the white pigment didn't take.
My next step was to seal it with Valspar Wet seal.
My questions are:
  1. Will the sealant fill in the grooves to give a smooth leveled feel? Or Would Epoxy be better for the job?
  2. Looking at the pictures, what would you do to give this a professional touch, or make it as clean as possible?
ALT. option
Should I build up the edges with melamine board so that it becomes 2 - 2.5 inches, then pour more concrete on top?
I greatly appreciate your advice and feedback. Im trying to make this look right. My wife is nervous it wont look good, but Im confident it can turn out [right. Just need a little help.
Photo 1 | Photo 2
SDsolar
  • 2,007
Layitdown33
Instead of just using sealant, it sounds like the best approach is sanding/polishing.
Pour-in-place produces rough concrete, as you have discovered.
Begin with very coarse sandpaper then as it gets more smooth you can use ever-finer grit until you achieve the surface you intended.
SDsolar
  • 2,007
