I while ago I asked this question while trying to install a smart switch. What's going on with this switch wiring?
The previous dimmer is a standard dimmer and it works fine. Lights have been incandescent and LED with no issues on that dimmer. New dimmer doesn't require neutral but does require ground. Would work at that location but worked in other spots.
Older home, old armored cable with 2 conductors and ground is through armor.
When I used a multi-meter to check the wires I got 120v between the two switch wires.
When I checked between each wire to ground (box) I got 70V from one switch wire to ground and 40V on the other.
What could be possibly be going on with this light/switch wiring and how can it be fixed?
OrganicLawnDIY
  • 3,811
  • 47
0 Answers0
