One of the propane rubber hoses in a portable generator has cracked and broken in several spots while the other one is in fine condition. As a stop gap a washing machine supply line was cut and used. Is there something about the propane that requires a special kind of material for the hose?
CW Holeman II
  • 501
Simple answer - yes, it needs to be rated to supply gas.
Two reasons:
  • water molecules are bigger, so permeability is less of an issue for water, hence your hose pipe may actually allow gas to escape
  • gas is explosive, so any mistake here may be considerably more serious than getting a water pipe wrong
If you need guidance, call your local gas company for advice - the good thing is that these pipes aren't expensive, so you'll pick one up for very little.
Rory Alsop
  • 3,096
  • 46
