I have about 500 bricks to cleanup so I can reuse them, the mortar is old and the bricks are soft clay.
What is the best way to remove the mortar and how much time should I allow?
  • 20,909
  • 95
  • 135
Walker
  • 6,275
  • 66
  • 87
There's two ways off hand that I've used in the past -- knock it off with a chipping hammer, or grind it off using an angle grinder and disk. The chipping hammer is actually easiest because you don't spend time fighting the tool or securing the work piece. Have a stiff wire brush on hand to remove the final bits and pieces that the chipping hammer doesn't get.
Karl Katzke
  • 7,915
  • 45
Get a small axe and using the thick end, hold the brick and just tap it. The mortar will come off in one go on that side. Hold the brick though, don't rest it on the ground. This way took me less than a hour to do all my old bricks.
  • 20,909
  • 95
  • 135
jann
