My dishwasher started leaking over the weekend. I turned off the water at the shutoff in the basement, it's a standard faucet type in the copper piping.
I then replaced the rubber heater hose used to feed water to the dishwasher, which had sprung the leak.
Trying to turn the water back on, I realized that the valve isn't opening. It turns repeated, and I've turned it many many times, but no water is flowing.
Is it possible that while turning off the water I stripped the thread, broke a washer, etc, stopping it from opening?
How can I fix this? Is it like a normal faucet that I can turn off the water to it, remove the packing nut, and replace the valve or whatever has broken underneath?
The valve itself looks something like: http://i.ehow.com/images/a06/6q/tm/plumbing-water-stop-valve-installation-200X200.jpg http://www.brass-plumbing.com/productsimages/brassneedlevalve_95381.jpg
Looking at those, what I'm wondering is if I can just remove the handle (which is broken anyway, I got a little rough), remove the packing not, emptying out the body, and replacing the contents with the header, nut, etc from a new valve. So I don't have to unsolder, the whole thing.
Also, valve and shutoff are new tag, so I can't create them, but would probably be relevant.
Aarthi
  • 1,143
Alex
  • 382
From the way you describe it, it sounds like it's a regular gate valve. You might be able to repair it as you describe by removing the packing nut and replacing whatever is broken or stripped out inside.
The only exception to that would be a ball type valve, but those will just have a handle that makes only a 1/4 turn. Those generally aren't repairable, but then again they almost never fail either.
Personally, I would just remove and replace the gate valve with a good ball valve. Gate valves have a tendency to rot out or seize up from lack of use. I actually had one once that disintegrated in my hand when I tried to turn it off (spraying water everywhere and making a nice mess). Ball valves are just much more reliable.
Eric Petroelje
  • 9,729
  • 42
  • 62
Gate valves have a gate that controls water flow. This gate is round and about 1/4 inch thick. Threads machined inside the gate valve mate with threads on the shaft which is turned by the handle. The threads on this shaft just break apart and no longer raise or lower the gate. Below the packing nut is a larger nut that you can turn to remove the handle, shaft and gate valve. My guess is this is a standard part same size for all 1/2 inch copper pipe shut off gate valves. Should be able to purchase another gate valve and just replace it his entire handle, shaft and valve asst.
