This might be 2 questions so I can separate it into two if needed.
I want to put a CO detector in two places of my home (kitchen and garage). However, the instructions that came with the CO detector said not to put it in there.
In the kitchen, I have a gas stove. I also want to put one in the garage because of the water heater.
I was reading the instructions for the CO detector. It said not to put one in either of these rooms. It doesn't state any exceptions (water heater/gas stove) so I don't know if it saying not to install it in these rooms is with or without the presence of these appliances.
Should I install detectors in these rooms or not?
Classified
  • 830
  • 35
No, you don't want to install CO detectors in the kitchen or garage, or too close to any gas-burning appliance.
You want CO detectors if you have gas appliances, but (somewhat ironically) you don't want to place the detectors close to those appliances. This is to reduce the number of false positives you get from the detector.
CO detectors should be placed on each level of the house, in each bedroom or just outside the doors if two or more bedrooms are close to each other.
mmathis
  • 8,959
  • 44
  • 66
It is always a good idea to follow the manufacturer's directions.
You do not want to install CO detectors near appliances.
You want them installed near people.
A living room or dining room is best. One for each floor, and near bedrooms.
But not in a garage or in a kitchen with gas appliances.
Also, remember to mount them near or just above the height of the average adult's face - that's 5 or 6 feet off the floor.
Here is a good article about them:
CO Detector Do's and Don'ts
In a nutshell, it says:
In order to ensure that your home has maximum protection, it's important to have a CO detector on every floor. Carbon monoxide detectors can get the best reading of your home's air when they are placed five feet from the ground. Near every sleeping area.
SDsolar
  • 2,007
