I'm in the process of buying a house built in the mid 80's. It was foreclosed about a year ago and has since undergone a large number of renovations (roof, HVAC, windows, doors, plumbing, etc). What are some specific things I should look for when doing an inspection on a house that has been flipped like this?
Steven
  • 27,770
  • 56
  • 90
josh-cain
  • 279
Check with the local building department to verify that they pulled permits and passed inspection for the work. They could have just covered up big problems that inspectors would have forced them to fix.
Even if they did get permits that does not guarantee that there are not still problems. Things that may have been hidden from the inspectors, just missed by the inspector, or some issues may just predate the "flip". You definitely will want an experienced home inspector to check everything thoroughly.
auujay
  • 5,315
  • 44
  • 55
In addition to the basics, seen in this answer: What are some of the best books/resources on home inspection for first time home buyers?, the fact that someone's been messing around with the innards of the house means you should pay extra attention to the areas you know they've worked on, and whatever's around it.
You mentioned they replaced the roof. Get up into the attic and look at the job from underneath. Do you see any signs of recent leakage (wet wood, drips, ice, stains)? Water damage that looks older MAY be OK, but if the wood appears rotten or mouldy, they didn't go deep enough in their demo when re-roofing.
Windows can be problematic. If the flipper enlarged the window frames, and did so improperly, this is a whole world of problems for you. They could have taken out the header, or installed a new one improperly, putting the weight of your house on the window frame itself instead of letting studs and plates do it. They could have weakened the jack or (God forbid) king studs which transfer the weight from the header and top plate down to the foundation, again around the window frame without putting load on it. If they cut out brick, they may not have installed a proper lintil in the brickwork. All of these can make the house settle down onto your window frame, making them hard to open/close and in the extreme collapsing the frame, breaking the window and making the structure above extremely unstable.
Doors are similar; you have to have a proper header, jack stud, and king studs supporting the frame, otherwise the structure of the house will bear down and collapse the frame onto your door, and you'll never get it back out. If the flipper changed out exterior doors, you may have some security issues related to the screws in the hingeplates and the strikeplate; if those don't go into the studs on either side of the frame, the door can be kicked open pretty easily.
Plumbing is also difficult for a novice to get right. Worse than electrical IMO, but I'm more comfortable with wiring work than plumbing personally. Unlike electrical wiring, water is dependent on gravity to work properly. Slope of the pipes, proper P-traps, proper installation of T-junctions and other joints to allow for the free flow of water (and making sure the joints don't leak), all of these are things the average home flipper looking to add a sink to the master bath and rearrange the shower and tub may not be taking into account.
To check for plumbing problems, first smell all the drains. If you smell sewer gas or general decomposition, odds are someone didn't put in a trap. Or, the trap has gone dry, in which case if you run some water down the drain and then come back and smell it later, the smell should be gone.
Then, for sinks, open the tap full blast with the drain open. The water should drain quickly and should not back up. If it drains slowly or backs up, you might have an improper slope on the drain line, or the sink might be too far from a vent stack. For tubs/showers, use the faucet to fill a bucket, then pour it down the drain. Again, the tub should drain quickly (though this is a lot more water than you were running down the sink so it will take a few seconds to drain fully). Check for leaks on all pipes you can see; evidence of drips, mould, etc etc.
KeithS
  • 14,367
  • 45
  • 74
Look behind EVERYTHING. A flipped house like that, chances are they went really cheap and covered over problems rather than solving them.
  • New floor in the basement? be suspicious. Are they covering flood damage, which happened a LOT in the past few years?
  • New walls? what's behind them...mold, bad wiring, rats nests? Cracks from the house sagging?
  • New plumbing? Really? New? Or just new to the wall?
  • New electrical? Are you sure? Did they pull permits? Are outlets loose? Did they use the "Home Depot Special" switches that only kind of work? Ditto for breakers, we had some breakers that didn't...break. They shorted.
  • New roof--Did they just pile a new one on top of serious structure damage?
Ask to see the estimates and bills from the workmen. It's been less than a year--they should still have the records. Go watch some Holmes Inspection for the horror stories if you get this wrong.
In general I would tell you to stay away, but at least do a really aggressive inspection. Ask them if they don't mind pulling things apart a bit so you can get a better look.
Alex Feinman
  • 3,532
