I did a google search and came back with industrial products, but no residential prosucts.
I have a System 2000 boiler and hot water tank. When the furnace is firing, the temp of the exhaust through the flue is around 400 degrees.
That seems like a horrible waste of heat.
Same thing with the dryer. It throws heat right outdoors, which also seems like a waste. (not really concerned with humid air, as it is winter and I have to run a humidifier anyway).
Is there any "safe" method to do recover waste heat from a boiler?
Jason
  • 421
You should look into condensing boilers that do just that and capture a lot of heat that would normally fly out of the chimney. In fact they vent through a PVC pipe producing a lukewarm steam and have efficiency as high as 96%
So if your current boiler is close to the end of its usefull life, then upgrade might be a sensible investment.
However it's not a bad idea to evaluate your house as a whole. If its poorly insulated and drafty, then that should be addressed as well.
A lot of states and some energy companies offer free or very cheap home efficiency auditing and insulation programs.
Vitaliy
  • 1,607
