I am trying to move an Ikea Pax closet. And even though I tried to gently remove the backboard (put a stick against the edge from inside along the board and hit the stick so it would distribute the power), it still left all the nails in. I removed the nails but now I am not sure I can reuse the backboard.
It doesn't look like Ikea sells replacement backboards (so much for their promise of helping re-use). I am sure Home Depot- or Lowes-type stores sell some kind of hardboard, but is there anything specific I should think of / ask for when getting it?
Or if anyone knows an Ikea parts replacement place that has the backboards, that would be even better.
Tyro
  • 57
StanM
  • 180
The backboard is part of the anti-racking structure and very much needed and used by just about every closet.
Backboard where the nails where pulled through can be reused a few times by putting the nails into new holes. At least until the edge is too chewed up.
As for replacement you can take a chunk of the board with you.
ratchet freak
  • 14,551
  • 42
This is a great time to upgrade to a better material. Ikea's backboards are the cheapest thing they can possibly use.
You could use a variety of hardboards, luaun plywood (which you stain to suit first) or even a clear or translucent polycarbonate and backlight it.
After searching, I found this great tip for taking the nails out of the back of a Pax. Worked like a charm. And, for me, I used this tip before I took the board off so the board survived.
Use a flathead screwdriver to pry the nails up. You can use a hammer to gently nudge the tip of the screwdriver under the nail head. Then the board stays mostly in good shape and can be easily reused.
Source: https://www.youtube.com/watch?v=sedYDd30a5U
To remove the back boards I use a long piece of wood from the inside over each nail point and give a a short sharp tap from a hammer.
That has enough force to fully take the nail strait out without damaging the board or anything.
To reuse the same hole I shove a tooth pic into each hole and snap it (snip it) flush.
P.s. I've moved about 100 of these wardrobes for people
