I have a table that has the legs drill-attached to the surface. The surface and the whole table is quite heavy.
What is the best way to move the table around a room if
1) it is not very easy to lift up and carry around
2) pushing it could be risky for the attached legs?
Jim
  • 481
If your concern is friction of the legs against the floor, you can get some of these furniture sliders. They will take that pressure off of the legs and allow you to push/pull the table without putting excess strain a the base of the legs. This is, however, assuming that you can lift at least one corner of the table at a time just barely enough to get one of these under there.
furniture sliders
hack3rfx
  • 1,324
