My inside water pressure is very low. My outside pressure is good. I did disconnect an old water softener and just connected the input and output pipes from the softener together. I would like to fix the problem myself without calling a plumber...Any ideas???
RHome
If you removed an old water softener it is likely you knocked loose some crud in the lines that has now moved through the pipes to your faucet. Take off the screen at the faucet tap and clean it out. It might not be the source of your problem but it's an easy item to check before calling a plumber.
  • 20,909
  • 95
  • 135
D.Sawyer
  • 79
