I would like to install a GFCI outlet in my bathroom. I attempted to install it beside our vanity mirror on first the left then the right side, but was unable to due to the construction of the wall, where the studs where placed too closely together. So, I decided to place the outlet on the wall opposite of the sink. My question is, how high from the floor should I place this outlet?
Thanks
JasonQ
On a wall there is not a minimum or maximum height. The question would be how high would you like it? If close to the basin they are usually placed several inches above the counter space but again no code height restriction on the walls. The one thing is it can not be placed in a wet location like above a tub unless outside the tub zone.
Ed Beal
  • 103,727
  • 79
  • 158
