So, I stupidly applied some polyurethane to my project without reading the instructions on the can. After it was dry several hours later, I finally read the instructions, and to my horror, I saw it said something like this:
Let sit for 30 minutes, then wipe off with lint-free reg. Do not let the finish dry without wiping it off.
So, erm, now what do I do? Did I ruin my project (it still looks perfectly fine..)? Why does it need to be wiped off, and what are the consequences if I don't!?
There's a chance you were using wiping varnish or a "tung oil finish" (not really tung oil). It's basically thinned down poly that can be left on in a thick coat, or the excess can be wiped off after a coat is applied.
The warning to not let the finish dry without wiping is probably good advice to eliminate the possibility of runs and drips.
Popular Woodworking has a good article on the history of wiping varnish.
Doresoom
  • 15,873
  • 83
  • 122
