I've just had a Carrier Infinity heat pump installed, with the matching smart thermostat. The only problem with it is that while it has three settings for the heat source:
  • Heat pump only
  • Electric heat only
  • System in control
There's nowhere to set the threshold temperature for electric heat. Where I live, you can have -30 celsius one day and 3 celsius the next day. Currently, system in control would still use heatpump at -30. Trying to pump heat with a 50 degree differential is not only inefficient, it also shortens the equipment lifespan. My previous thermostat, nest, would switch to auxillary heat below -6 celsius.
Reseller was supposed to tell me how to access the admin settings but doesn't ever get back to me. Is there a general approach to figuring out where this setting is? The thermostat UI doesn't seem to show it anywhere.
Data about what I've got installed: (snippet from a french invoice, so apologies for my french)
25VNA036A003 HEATPUMP CARRIER INFINITY GREENSPEED 3
FE4ANF003L00 FAN COIL 2-3.5 TONNE VITESSE VARIABLE 1
KFCEH3201F20 ÉLÉMENT ÉLECTRIQUE 20 KW 1
SYSTXCCITC01-B THERMOSTAT INFINITY TOUCH WALL 1
(I can handle a voltmeter and I can also capture the network traffic of the device connecting to the infinity server, if this is of any help)
Jeffrey
  • 2,055
  • 25
  • 37
0 Answers0
