I am making hurricane panels for my house using the technique described here.
The plywood I purchased is pressure treated. The sliding bolts are zinc, so I assume the screws that came with them are also zinc. Is this ok, or should I be using different screws and/or bolts?
Doresoom
  • 15,873
  • 83
  • 122
longneck
  • 21,448
  • 52
They are not actually zinc, but zinc-coated steel, also known as galvanized steel.
The treated-wood industry recommends the use of hot-dip galvanized or stainless steel fasteners for use with treated wood. Electroplated/electro-galvanized and mechanically-galvanized coatings should not be considered to be hot-dip galvanized. (Class 55, or higher, mechanical galvanizing provides galvanizing equivalent to the hot-dip galvanizing used on connectors and fasteners.)
Source: Strong-Tie's pressure-treated wood FAQ, which has additional information about various kinds of pressure-treated wood, galvanized steel, and stainless steel.
Vebjorn Ljosa
  • 9,705
  • 62
  • 90
