Home inspector once told me my basement has a slightly high moisture reading.
No mold, dampness or musty smell.
I am building an entertainment built-in out of lumber and MDF.
Should I use pressure treated lumber where the wood will sit in contact with the concrete floor/foundation? The rest will be standard 2x4 lumber.
Marinaio
  • 1,674
  • 48
If you'are trying to save money you could use regular lumber with sill seal, then the wood will not come in contact with the concrete. https://preview.tinyurl.com/yc5zzslh The URL takes you to a preview first and then provides a new link.
Most building codes require PT wood that will be in contact with basement concrete floors. So the bottom plate of a 2x4 wall and code requires the use of fasteners (galvanized) approved for use with PT wood.
Yes you should use naturally durable (Redwood, cedar), or preservative-treated wood (AWPA U1 and M4) for sills or sleepers on a concrete or masonry slab that is in direct contact with the earth if you want to do it by the book (IBC 2304.11.2.4) and its also a wise idea.
freshop
  • 1,926
