i'm going to drill into a wall interior and avoid the wires immedietly above the socket and horizontally near it below If I remember my dad told me that wires are normally found travelling vertically above and below the socket. The socket is near the floor should I worry about any horizontally running wires either side?
Wires 'NORMALLY' travel down into the socket; however if the sockets are daisy chained (and an outlet most likely will be) in other words you will have more than one socket on a circuit; you will have wires traveling horizontally to the next outlet. I said normally - because you never know how those wires were stretched across the space etc.. unless you physically saw them before the dry wall was fastened.
You can use a stud finder with a wire detector to determine where wires are (~ $40) - to some extent they work.
There are non-contact voltage detectors that might find it for you.
Then Of course there is a product advertised on TV that will allow your android or iPhone to see through the wall .. the wires, the pipes and whatever. While not cheap it is probably the best tool you could use.
- 5,453
- 2
- 18
- 33
When I had this problem years ago, I resolved it using my own improvised detection method. And it worked 100% accurately.
Before I discuss the method let me to point out about the limitations of the standard gadgets being sold for this type of detection.
Voltage detector: it may detect the hot/live wire but tell you nothing about the neutral/return wire. Normally both hot and neutral are bundled together but this not necessarily be real for all installations. Using this, you may end up drilling into a neutral wire.
Stud finder: works well in detecting ferromagnetic materials such as iron nails or steel screws. Its sensitivity drops sharply when being used to detect buried copper wire. I might be wrong on this but I don't have much confidence on this gadget to detect buried thin copper wires.
My method; Listen to the line frequency of electromagnetic wave emitted by buried wire when it carries a large current.
The gadget:
I improvised an old "walkman" type cassette player by hooking up a one-inch small 1000 turns copper coil to the wires originally connected to the player's tape head. This copper coil actually from a primary of a small power transformer, with its iron core fully removed. This modified player become a sensitive magnetic field detector. Whatever signal picked by the coil can clearly be heard thru earphones connected to the 'walkman'. This gadget picks electromagnetic field of AC current carrying wires from as far as 18 inch distance.
Method: Detect one conductor at a time. I load the circuit in such a way so that current flows only in one conductor at a time. This is done by connect a significantly heavy load such as a 100 watts or 500 watts halogen lamp to the live wire of that socket and get the neutral return for the lamp at another socket some where else.
This ensures my gadget can listen only to the magnetic field around the buried live wire. When the pickup coil is sweeped on the wall, the intensity of the line frequency signal peaks at its closest position. This is how I locate the position of the cable run.
Repeat this for neutral wire by loading the lamp on the neutral wire and get it live feed from some other far socket.
- 158,133
- 9
- 190
- 463
- 260
- 1
- 11
