I have a 40cc Craftsman 18" chainsaw, and was cutting and the chain stopped moving. Earlier it would rotate freely when I started it, even without pulling the trigger. Now it does not move at all. I'm nervous to pull it too hard, and wonder if it's just some safety setting that I accidentally triggered. Any advice?
Asked
Active
Viewed 3,728 times
My saw has a brake that can protect me in case of a kickback. It sits in front of my left hand. Push forward to engage, pull back to release.
Or it could be a maintenance issue:
- Do you fill the bar oil when you fill the gas?
- Do you clean the machine after using it? Including the drive gear and the slot in the edge of the bar?
- Do you loosen the chain when putting it away? As the chain cools it contracts, and you don't want to let it get overtight. I store it loose; snug it up before using; adjust after 5-10 minutes use, when it's warm; the release when putting away.
- If you remove the bar & chain, does the drive gear spin?
Jay Bazuzi
- 11,778
- 34
- 100
- 143
