I am a first time fence builder, which will be 6ft cedar. I need a gate that is 7 to 8 ft wide. I live in Oregon and the frost line is only a foot deep. I was planning on a 7ft gate with a 6x6 post. Would that hold the gate? How deep should I sink it?
I also thought of 2 4ft gates on 4x4 posts but have the same questions.
The gate won't be opened a lot, just provide access to a barely used trailer and a dog run. I am concerned with the weight and that it might sag.
  • 20,909
  • 95
  • 135
Tim
  • 101
5 Answers5
An eight foot wide gate is going to be very heavy and most likely will sag and drag on the ground. I would recommend two four foot gates. As far as the foundation for your posts, to support a swing gate, they should be at least 36 to 40 inches in the ground and in at least a 12 inch diameter concrete sauna tube. Frost is not your enemy here, but rot and lack of ballast is. The gate posts need to be heavy at the bottom and very firmly compacted into place. If the posts move under the weight of the gate, you will be greatly disappointed. Spend the time to make sure they are as secure as possible. The more concrete, the better.
shirlock homes
  • 58,628
  • 87
  • 168
Rule of thumb is that 1/3 of the post should be in the ground. A 6' fence should be sunk into the ground 3', so you'd need 9' posts.
As Shirlock states, even that won't likely support an 8' wide gate. Two 4' gates would definitely be a better option.
Perhaps the easiest solution, however, is to not even make a gate. Instead, build your fence and then make this an 8' panel that is attached with temporary fasteners...such as bolts. On the rare occasions that you need access, unbolt the fence panel and remove it completely--thereby negating the need for the two posts to cary the load of a cantilevered gate.
On the plus side, it's less gate hardware you need to buy and deal with.
DA01
  • 24,586
  • 82
  • 153
Yes, 6"x6" posts properly set will work just fine. I have several 8, 10, and a couple of 12' gates on my property. Make sure to measure for post length as you plan to level and set each post in concrete/quickcrete at least 2 and 1/2 feet each. If your gate is very heavy, you can certainly add a wheel. I don't believe it is necessary. I only have a wheel on my gates that are over 10'. A support cable could be added for exceptionally big and heavy gates. However, I do not believe you will need that. Also, a cable requires a very high post to secure. Keep in mind, your fence attached to posts will provide support as well. I hope this helps. There are several google instructions for setting gates. I also suggest some research that will be very helpful. Best regards.
Vicki
have the same problem,what I did was with a featherboard fence,where I needed occasional access .firstly as stated above make sure supporting posts are substantial secondly made a panel to fit thirdly only attached to said posts with the minimum of screws.If I needed to remove it would be easy and when we had severe gale recently panel popped out and needed little repair to replace
-1
I am doing a fence right now it is a 8’x7’ gate . I am using 4"x4"x1/8" steel posts 2’x4’deep holes, hand dug or a vacuum truck then filled with concrete .no compacting around hole is the best just keep your hole sides tight and keep the concrete down 5’’ to allow for driveway crush and pavement. And 6" deeper for some crush so the posts don’t sink.
