I am planning to event a fence this summer and, given the size of ~ 250 linear feet, am looking for the cheapest option for cementing the poles. I am considering the use of metal Postmaster (MasterHalco) posts and plan to set them 4' in the ground in ~ 8' holes as I am up north and the frost line is ~3.5 feet. enter image description here
I have checked out multiple types of fast dry concrete specifically designed for fence post but would like to find a cheaper option. Is a standard portland concrete mix acceptable for this application? If Yes, what ratios of cement/sand/gravel should be used?
Also, are sonotubes recommended?
Thanks
mmathis
  • 8,959
  • 44
  • 66
MSK
If you are going that deep in the ground, your fence posts will be plenty stable by placing and packing the dirt back around them. To pack the dirt I use a 2X4 with the end cut down to size and rounded for a better feel as a handle, and for tighter places I use a 1X4. I would only do concrete around them if you are setting a large gate to a post.
If you must use portland, instead of the just add water type, the mix ratio is 1-2-3. 1 shovel portland, 2 shovels sand, 3 shovels gravel.
Jack
  • 38,117
  • 66
