I'm trying to drill pilot holes through my exterior door frame in order to install a weather seal.
I purchased a few new cobalt drill bits labeled for hardened steel.
However, each new bit was only able to drill one pilot hole before losing its ability to drill holes.
After two bits, I tried applying some oil to a third new bit to keep it from overheating, and while that worked in keeping the bit cool, it still was only able to successfully drill one pilot hole. After the initial hole, the bits stopped working and could no long drill through the steel.
Any thoughts?
Steve
  • 133
5 Answers5
If it is possible that you used the drill bit with the electric drill set to the wrong rotation direction, without realizing it, the freshly ground new drill bit will likely be able to drill a hole through the thin steel but at the same time will dull and round off sharp edges so much that a second reverse operation would never start to cut into the metal.
The electric drill has to be setup to rotate the drill bit in the direction shown in this picture:
Michael Karas
  • 67,833
  • 68
  • 153
A Steel Step Drill Bit.
This is what I have used to drill through steel beams. Mind you this is much cheaper than what I use for commercial use but still works very well and can be found on Amazon or most hardware stores.
$10 Amazon.com link
norcal johnny
  • 1,613
Use a masonry bit! Don't believe me just try it. You may need to sharpen end a bit into a pointy arrow type shape, med speed, grease the drill site, reasonable push as you drill
You don't mention the specifics of the technique you tried, so I'll offer general metal drilling advice:
  • Drill slow. Assuming you have appropriate drill bits, the thing that is dulling them is too much heat. As a test, if the bit is too hot to touch, you're going too fast.
  • Use Oil. This reduces friction (heat) and helps dissipate heat. Any type of lubricating oil will do in a pinch, but cutting fluid is designed for this.
  • Use a Step Bit for larger holes. These function essentially as progressively larger pilot holes, so you're not cutting so much metal at once. Not necessarily applicable to your scenario.
Rob Elliott
  • 630
You do not have hardened steel doors . Your bits are almost certainly dull from turning too fast with-out enough pressure. Get new sharp bits, you don't need high speed steel but most of them claim to be that. Turn the bit slowly with a variable speed drill , with high pressure and oil. You should see metal shavings quickly. Drilling in a spot where you spun the bit previously will be more difficult because that steel will be cold worked. Cold working can easily triple the hardness of the steel ; maybe you do have hardened steel doors ( in small spots). It will be easier to start with a small bit then a larger bit. The oil is mostly to lubricate; real high speed steel will cut at 1000 F so cooling is not so important. The gold color on bits is a very thin layer of titanium nitride ; nitriding is also done on steel but is just black. Carbide point mason bits have poor geometry to cut steel.
blacksmith37
  • 8,401
