So I had an old panel and subpanel replaced with a single new panel. The guys reused the old breakers, and the breakers wobble in the panel like loose teeth. With the old panel, they didn't wobble at all.
Is this because the breakers don't fit the new panel, or were they just not tightened down enough?
The breakers are GE type THQL, 1 pole units. The panel is a GE PowerMark Gold Load Center, type 1 indoor enclosure, model 6.
ThreePhaseEel
  • 87,685
  • 144
  • 243
Korzak
  • 141
Replace the breakers
I'm not precisely sure what's going on here, but replacement breakers should cure the wobbling issue, once and for all. It might be an issue with old TQL (or early THQL even?) breakers not fitting properly into a new Q-line panel (as documented here), or it could simply be that the line-side jaws on your breakers are not in good condition any longer -- either way, the cure is the same.
ThreePhaseEel
  • 87,685
  • 144
  • 243
