15
I plan on adding a Cat 6 network in my single-story detached home. It would consist of home runs from each of the 3 bedrooms + TV room to a central patch panel in the garage, which is close to the center of the home. The cat 6 cable runs will follow the existing runs for cable tv (coax) in each room. i plan on replacing the existing coax faceplates with keystone faceplates with coax & cat6 keystone jacks.
Since the network cable will be run in the walls and the attic, would code dictate that I use riser (CMR) or plenum (CMP) rated cables or will general purpose (CM) Category 6 cable suffice?
If it matters in regards to the electrical code, home is located in Calfornia (SF Bay Area) & was built in 2003.
funkadelic
  • 315
Since you are in a one-family dwelling, there is really only one important article to be aware of.
800.26 Spread of Fire or Products of Combustion. Installations of communications cables and communications raceways in hollow spaces, vertical shafts, and ventilation or air-handling ducts shall be made so that the possible spread of fire or products of combustion will not be substantially increased. Openings around penetrations of communications cables and communications raceways through fire-resistant-rated walls, partitions, floors, or ceilings shall be firestopped using approved methods to maintain the fire resistance rating.
FPN: Directories of electrical construction materials published by qualified testing laboratories contain many listing installation restrictions necessary to maintain the fireresistive rating of assemblies where penetrations or openings are made. Building codes also contain restrictions on membrane penetrations on opposite sides of a fire resistance–rated wall assembly. An example is the 600 mm (24 in.) minimum horizontal separation that usually applies between boxes installed on opposite sides of the wall. Assistance in complying with 800.26 can be found in building codes, fire resistance directories, and product listings.
In a one- or two-family dwelling, you can use general type cable (CM, CMG, CMX) anywhere other than where plenum cable is required.
800.154(B)(3) One- and Two-Family Dwellings. Type CM and CMX cable shall be permitted in one- and two-family dwellings.
Or, under carpets.
800.154(C)(6) Under Carpets. Type CMUC undercarpet communications wires and cables shall be permitted to be installed under carpet.
