I have a shower stall with a drain that is going unused. My first concern is that if the water evaporates out of the plumbing trap below, I could have sewer vapors coming up, so I pour in some water periodically. However my second concern is mosquito larvae growing down inside there since it's so infrequently disturbed i.e. flushed out. I've seen mosquitos in that bathroom, which makes me suspect this problem.
What's the best approach here to prevent both sewer vapors and mosquitos? I've thought about a one way valve for the drain, or maybe pouring oil or human-friendly insecticide down on the water in the trap.
How would you handle this?
WolfRevokCats
  • 123
Pour in some heavier liquid, like vegetable oil. Or put a plastic container lid over it, with a little weight on it so it doesn't accidentally move.
CrossRoads
  • 111
I was able to purchase pipe plugs with a wing-nut and gasket that you slip into a pipe, turn the wing nut to tighten the gasket and the problem is solved. Try to "GOOGLE" Cherne Industries for an example. I use the yellow ones. I think I bought them at a home store, the orange or the blue store.
d.george
  • 12,593
After reading online, the approach I decided on was to pour detergent (liquid soap) down into the drain. My plan is to periodically add water to keep the trap filled and avoid vapor backflow, plus add this detergent so that mosquitoes that touch down on the water will be sucked in and drown due to the effect of detergent on the water's surface tension. Soapy water also works as a sort of home remedy flea trap.
I am accepting this answer since it is what I went with, however would like to recognize others who posted answers that may be just as good (or better). If I have problems with my approach I will revisit this question and may choose a different answer. Thanks, all.
WolfRevokCats
  • 123
I've been wondering about a similar thing for a drain that is used intermittently. I stumbled upon these seal that one can add to a preexisting traps to prevent evaporation and the back-flow of fumes:
Sure Seal
Quad Close Stink Stopper
Green Drain Super seal
But I swear once upon a time I saw traps that use something like a floating ball instead.
virtualxtc
  • 2,647
  • 50
