I'm building a project that involves sliding drawers. I'm shopping for drawer slides and I'm not sure what the 16" in the title below refers to?
Does it mean the drawer hardware is 16 inches closed? Like the length of the track closed is 16 inches? Or does that mean that I can pull it out of the box 16 inches?
16-Inch Full Ext Drawer Slide 100-Pound Capacity Side Mount
Brad Mace
  • 2,505
  • 48
studiohack
  • 173
It means the slide is 16" long and that you can pull your drawer out a full 16" relative to the slide. If your cabinet space was 20" deep, and you mounted this all the way at the back then your drawer would not come out 16" but instead 16-4=12".
Steven
  • 27,770
  • 56
  • 90
16" refers to the length of the slide when closed, which will usually also be the depth of the drawer you're installing them on. Your cabinet (or whatever you're installing in) would need to be at least 16" deep, plus the thickness of any false front you may have on the drawer if you want to make them flush.
It's also a nominal length--I just bought these exact slides and they actually measure 16 1/16" long. This little bit of extra length shouldn't be a problem since you should be leaving yourself at least 1/4" extra depth anyway.
"Full extension" tells you that you can pull the drawer out as far as the slide is long: 16". Slides also commonly come in 3/4 extension (which would mean 12" of extension in this case), or 1" over-travel (17").
Brad Mace
  • 2,505
  • 48
