I recently discovered that the overflow drain that is supposed to be connected to the overflow outlet on my bathtub is...well, not. Taking off the cover of the overflow outlet, I see the pipe freestanding and disconnected, a couple of inches away from the hole.
This explains that strange waterfall sound I heard while taking a bath a few months ago, but more importantly I want to fix it now that I know about it. There is no access panel (which, since the whole bathroom was renovated by a big box store right before we bought it, is yet another item on the list of "You've Got To Be Kidding Me").
To complicate matters, the pipe is offset from the tub hole by about an inch. The drain pipe is sitting higher than the hole of the tub. This is probably why they didn't hook it up to begin with.
What I need is to fix this; reattach the drain pipe to the overflow hole in the tub. What I want is to fix this without cutting an access panel or basically any plumbing of any kind. Any ideas?
dolphy
  • 658
All you need is a thick wire that can be bent into a U-shape at one end. Place the cover back into the outlet hole, insert the U-shaped wire into the outlet pipe and try to grab the outlet pipe to hold it in place. Lift the outlet pipe and slowly screw the top cover to the outlet. Tighten the top cover to the outlet pipe with a pair of pliers.
  • 20,909
  • 95
  • 135
user12727
Is there any flex in the overflow pipe? You may be able to pull it to the opening, but don't force it. Install a gasket between the tub and the pipe, and re-attach it.
I guarantee you that this will be frustrating and annoying, but it is possible. An extra pair of hands will help.
Chris Cudmore
  • 14,169
  • 61
  • 91
A series of screws, the first one long enough to reach the tube, each one 1/4 inch shorter than the next, until you get to the correct length screw.
First install a new gasket and then starting with the long screw, screw it down until it bottoms out. On the other side, use the next shorter screw, pulling the tube just a bit closer. Alternate between the left and right sides until snugged.
HerrBag
  • 12,225
  • 37
