We recently had a whole new system installed for HVAC.
We had a lennox furnace with dehumidifier and UV thing, along with the exterior lennox condenser for A/C.
We have the iComfort S30 thermostat, and have the temperature set to:
Temperature: Heat to 68, Cool to 75 Humidity: Humidify at 45%, Dehumidify at 60% Humidification Control Center: NORMAL operation Dew Point: Off
However, I live in Michigan, and the outside humidity is around 68-79% on average. Now, the temperature in my house is currently 67 degrees. It is around 76 outside. The A/C is running, well it seems like it is - since the dehumidifier is running. The screen says the current humidity is 68%.
So even though the temp is WAY below what our cool-to temp is set to, it is still chilling the house to that akin of a freezer. Not only is it monstrously uncomfortable to live in, it is also going to drain my bank account.
What do we do?
Barry Chapman
  • 219
It sounds like the system is not actually "cooling". It sounds like it trying to dehumidify. An A/C system actually is a dehumidifier by its design. If the Temp of the residence is satisfied, and the A/C is still running, try turning up the humidistat higher. if the system turns off and returns to normal, then that is the issue. if it keeps running, then you will need to call a tech to come look at the system.
Tech
  • 164
