14
The lights on my harbor breeze fan stopped working this morning. When I came home from work, I got the ladder and took down the lights. I don't have a multimeter but I saw that there is this Watt Regulator (pic below) in the fan. I traced the wires and it seems that this may have been the culprit. I snipped the wires, got some wire nuts, and wired directly into the 120V circuit. Ta-da! Lights are back and fan is working normal.
Question is : What is the purpose of this watt regulator? Why do some fans include it?
alt text
Here's the real story:
http://www1.eere.energy.gov/buildings/appliance_standards/residential/ceiling_fans.html
As required by the Energy Policy Act of 2005 (EPACT 2005), the U.S. Department of Energy (DOE) has established test procedures and energy conservation standards for ceiling fans and for ceiling fan light kits.
Ceiling fan light kits with any other socket type including but not limited to candelabra screw base sockets, intermediate screw-base sockets, 2-pin halogen sockets, and bayonet sockets manufactured on or after January 1, 2009, shall not be capable of operating with lamps that total more than 190 watts and must be packaged with lamps that together total 190 watts or less. DOE indicated in a January 11, 2007, final rule that it recognizes that manufacturers may choose to follow one of several possible design pathways to ensure that the light kit is not capable of operating with lamps that total more than 190 watts.
http://www.regulations.gov/#!documentDetail;D=EERE-2006-TP-0121-0003
DOE is interpreting the 190-watt limit on power consumption for certain ceiling fan light kits as a design requirement. This approach will require that manufacturers incorporate some measure such as a fuse, circuit breaker or current-limiting device to ensure the light kit is not capable of operating with a lamp or lamps totaling more than 190 watts.
Philip Ngai
  • 3,503
The Wattage regulator has nothing to do with speed of fan or brightness of bulbs or for a remote. It is a safety feature that prevents the fan from overheating. If you install bulbs that exceed the specified wattage, the wattage regulator either shuts off the bulbs or limits the wattage they receive to prevent overheating. Contact the manufacturer and they should send you a new light kit.
Diveon
  • 61
A regulator would normally be used either to change the speed of the fan or the brightness of the lights. If this regulator didn't have any external controls like a pull chain, is there a chance this fan at one time had a remote control?
Mike Powell
  • 9,394
  • 25
  • 43
