So I've got a warehouse with many fluorescent tube fixtures. We are slowly transitioning piecemeal to LED as we run out of replacement ballasts and bulbs.
I've got a fairly simple troubleshooting technique:
  1. Are both tubes out? Probably the ballast.
  2. Test the fixture with a known-good tube.
  3. If known-good tube works, then the ballast is fine. Replace both tubes.
  4. If the known-good tube doesn't work, the ballast is bad. Replace ballast or retrofit to LED.
  5. Is only one tube out? Then the ballast should be fine (???). Replace the bad tube.
So here's where things are weird. I've got two fixtures now where one tube works, and the other one doesn't. But even when I replace the bad tube with a known-good tube, it doesn't work.
I've checked the wiring and it's fine. On one fixture I even saw the tube "burn out" - and that fixture has been chugging along for years without any intervention. It would be weird for it to suddenly develop a wiring problem out of nowhere.
I guess my question is, is it possible for a ballast that supports two tubes to fail on one tube only? I didn't know this was a failure mode for electronic ballasts. But maybe it is an internal wiring problem...
Daniel
  • 221
I buy most of my ballasts on ebay for a couple of bucks, they are new pulls (seller bought new fixtures and immediately converted to LED). I combine them with the newest 90+ CRI tubes ($2 each) and the light is amazing! Don't look at the fixtures, look at the stuff the fixture is lighting up.
ALL fixtures can take electronic ballasts, I have converted some 1940 era fixtures (after giving them a trip through the paint shop). Those old fixtures are well built. The only exceptions are very cheap fixtures with weird unobtanium tombstones or no space to fit a ballast.
If the ballast is instant start, it is possible for an electronics failure to take out one side. But it's more likely a tombstone problem (or wiring). A bag of spare tombstones (60 cents ea. at 1000bulbs) is essential even if converting to LED.
I dislike instant start ballasts and prefer rapid or programmed start when obtainable at sane price. You want programmed start for hard to reach locations or frequently cycled lights e.g. Bathroom or on a motion sensor.
Tubes don't "burn out", they get dimmer, scorch their ends and then flicker or barely light. An abrupt failure is tombstone or ballast.
