Possible Duplicate:
Can I build a deck this low to the ground?
Every set of instructions I've seen for building a deck requires me to put joists on top of beams attached to posts. But I only have 6" clearance above the ground. In other words, not enough room to stack the joists on top of the beams.
I'm certain I'm not the first person in the history of the world to do this, so how do I do it? Do I use joist hangers and run the joists between the beams creating a grid? Or do I need to bury tons of posts and attach the joists directly to them (I hope not!)
RickMeasham
  • 173
Joist hangers would be fine. You can bury concrete post piers to act as your actual piers as well. Do try to leave at least a few inches of clearance though th facilitate air flow so it doesn't get too soggy underneath.
But when building a deck that low, I'd suggest you also consider a patio, instead. A stone, concrete or tile patio will outlive any wooden deck.
DA01
  • 24,586
  • 82
  • 153
