I recently moved to a new home which had a lot of felled trees which needed to be bucked up into logs. I bought a 14" Husqvarna 967158004 to accomplish this.
The shop I bought it from gave me a lot of maintenance information which was greatly appreciated because I don't have extensive experience with chainsaws. I have checked chain tension before and after every use and kept the chain oil reservoir full.
My concern is that after what couldn't be more than 8 or 9 hours of use, the chain already seems to have trouble cutting ( Engine is good, this is a cutting issue ).
Is this typical wear I should expect?
Do I need to replace the chain or should I sharpen it?
I know it can be resharpened, but is it worth doing so?
Alaska Man
  • 13,792
mreff555
  • 1,289
Yeah, when I first started using chainsaws, I was naïve to the idea of "sharpening a chain". The very fact that you were able to get 9 hours out of it tells me you were like me. My first chain, the chain cut subtly worse and worse and worse and worse, and I didn't realize it, because like the frog in the cookpot... until I couldn't stand it anymore.
First I paid the local lawnmower shop to sharpen them. Then I discovered my local Stihl dealer would swap me for a new chain for $10. After about 3, he sold me some chain files. Then I found a $6 flat file holder that makes filing much easier. Files are a consumable, and I don't even try to adjust chain height: when the height is low I just go back to the Stihl dealer and get a new chain.
Now, I can't stand how badly my chain cuts after even an hour. I typically give it a quickie sharpen everytime I add chain lube, and it cuts like a lightsaber again.
Any blade (even a lawnmower) will dull after constant use, but a chainsaw is doing a lot of work, and most of it by the blade.
I would say your blade is indeed dull. The catch on what to do from here is dependent upon how often you intend to use the chainsaw. If this is a one-off project, you're probably better off buying a new chain. If this will be a regular thing, I would buy some tools to sharpen the blade. The cost of a new blade is comparable to what you would spend on sharpening tools.
Machavity
  • 26,498
  • 44
  • 100
I suggest you buy files and do the resharpening manually. It saves some bucks and time. If you don't want to do the labor, there is electric chain sharpener which works pretty good.
I always keep 3 extra chains with me. When one gets dull, I replace it and continue the cutting. At night, when I come back home, I sharpen them all one by one.
Chris Ross
