I’m dealing with some 1930’s era steel casement windows, Tudor revival style, that are in reasonably good shape for the most part. They need some maintenance and would like some suggestions for how best to handle this as gradually applied DIY work.
Some windows aren’t fitting so well and are hard to close. I’ve used WD-40 on parts and cleared out excessive paint layers that were in the way. This helps but perhaps there is warping that needs to be addressed? Anyone have experience with this?
Another thing I’d like to address is draftiness. The windows are just steel, no gasket material anywhere. That may have been the original design, or perhaps the gaskets all disintegrated over the years? Are there standard practices for ensuing well sealed steel windows? There is a sizeable air pocket between the outer and inner mating surfaces that perhaps was where a gasket used to live.
Finally, I’m wondering if there is a way to replace the single pane glass in the casement with double pane or some more insulative glass at reasonable cost. The pocket is probably deep enough to fit standard thickness double pane glass, but I don’t know any supplier that produces double pane glass in such a small size that I could glaze into there. Is that even something I would want to do? I’m guessing it would cost a lot, even for a few windows. I’m familiar with window films that can help with radiative losses, but perhaps there are other window glass options I should consider? Any laminated options, like what some cars use, for strength, acoustic, and thermal improvements?
eug-
I have steel casement windows, love the look. House is unquie and beautiful. However in the NY winter they are a problem. I got a product that made a huge difference called a Indow. Expensive, but it’s a custom fit for each window frame of hard plastic w foam edge around. Creating a second barrier to single pane glass. Made a big difference...I’m slowly getting to more windows in house. For the ones I don’t have yet, and very big windows I use the 3M plastic sheet shrink wrap.... it’s time consuming but works. If you can recommend a weather strip I would add that
Jim
There are suppliers of replacement casement window parts (latches, hinges, operators tracks, etc.) who can help you refurbish the windows.
Be aware that there have been dozens and dozens (hundreds?) of manufacturers and models and types over the decades and decades. Lucky for you a lot of the hardware is still available, start researching.
As for weatherstrip, you should carefully examine the windows to see if you can determine how they were originally equipped (including examining similar windows in neighboring homes and even other buildings), then try to procure OEM weatherstrip. Failing that, there is aftermarket strip of many types that you might be able to make work.
As for somehow inserting dual-pane glass in your existing casement frames... dubious. You should plan on applying other insulation tactics (like the film you mentioned, and weatherstrip).
Jimmy Fix-it
  • 37,916
  • 35
  • 62
Found this National Park Service site with some information on how to restore steel windows:
National Park Service Preservation Brief for Steel Windows
It includes some information that addresses my concerns about operation (opening and closing), weatherstripping, and glazing options.
eug-
