I have a hardwood floor I've recently finished staining. I'd like to apply polyurethane but I don't think I can cordon off the entire area for the duration. Is it alright to apply the sealer in sections?
Danny
  • 153
Surface finishes are notoriously difficult to get smooth when the process is interrupted. The glossier the finish, the harder to have sections blend.
If you are talking about preliminary coats, especially if they will get a light sanding between coats, this is probably ok. For the finish coat, I would strive hard to do it all in one shot.
If you simply cannot, try to find a transition area that will be less noticable, such as an area covered by rugs or furniture. You also might try cutting the transition from one section/session to another along a long board line, but this is hard with poly.
bib
  • 33,975
  • 68
  • 102
I highly recommend NOT seperating the coats. You will see a visible line where you stop and start again and the sheen won't exactly match. Definitely go with a water-based polyurethane as Mike suggested for a quicker dry time. I know it's exciting to want to complete the project but don't be afraid to be patient with your floors. They're a lifetime investment and worth the care and additional wait.
  • 20,909
  • 95
  • 135
