I'm planning to get a quartz countertop. One contractor told me that all brands of quartz are the same quality since they use the same patented process. Two other contractors told me there is a quality difference among brands. I've looked online and haven't found any definitive answer
Is there a quality difference in quartz from different companies, or are the differences only cosmetic? My highest priorities are durability and ease of care.
mike65535
  • 1,559
Yes, they are polyesther , often called "epoxy", with silica/quartz fill. Different grades of polyesther are used , cheaper ones are diluted with more styrene monomer. And different concentrations of fill. An installer could likely give an objective evaluation of different brands. However, ours were made at a local shop that I visited and I could imagine there is some difference depending of the operator ( for locally produced tops).
blacksmith37
  • 8,401
If you are going with quartz I suggest Silestone. I worked with it for years and it is very consistent.
DSH72
  • 171
Yes there are definite differences in the quality of Quartz, the amount of epoxy fillers, etc. For the most part, silestone, Caesarstone, and cambria offer the highest quality.
