I'm painting a room that had previously been wallpapered. The walls are veneer plaster coated, so the paper was easy to remove and clean the plaster. However there are patches for wiring, dings and other artifacts of sloppy plastering that I've covered with regular joint compound.
As I start painting (latex) I find that unless I'm really quick and wet across the compound, it starts to come up and ruin the finish.
Should I be spray priming? What do others do about this issue?
DaveM
  • 2,775
A primer is recommended for joint compound. Using a primer seals the mud and actually uses less paint with a even finish in the long run.
Ed Beal
  • 103,727
  • 79
  • 158
If you find you're doing a lot of patches, buy some "new drywall" primer. It's cheaper and helps you get the new compound ready for paint just as well (it's also latex). It generally is only available in gallons, though (with the assumption you've done a whole room in drywall)
If you're not doing a LOT of patches, consider using a better patch. Joint compound is different from vinyl spackle, and some types of spackle come pre-primed now.
Machavity
  • 26,498
  • 44
  • 100
Huh? Of course you will. Always.
Anytime you put topcoat paint on a surface that is inconsistent, it will show inconsistent results. The topcoat will react differently to different surfaces, leaving a different texture that will be noticeable.
That is the entire point of primer. You paint primer over the mixed surface, the primer seals it, and after 1-2 coats (possibly with some help from sanding or filler in between primer coats) you have a surface that is uniform (consistent/the same) - it's all dried primer. The topcoat applies evenly.
Primer also causes the color to be uniform, because otherwise, underlying different colors will print through (most architectural coatings are near-white, and white paint isn't that opaque).
Primer is optimized to do this. It's also cheaper. Paint can do this too, but it'll take ridiculous numbers of coats of it.
It sounds like the joint compound was applied over a paste residue that is reactivating from the moisture in the paint. It can be very near impossible to get all adhesive washed off of the surface. That is why I always use a sealer before patching. Best one I have used is Gardz by Zinnser. It creates a thin barrier coat that locks down containment’s on the surface. After it drys do your patching and sanding followed by spot priming of repairs with same product. –
Kris
  • 4,560
