I am working on creating blueprints for my new home. My plan is to have both solar panels on the roof and a rainwater catchment system that directs water from the roof into some tanks in the basement. I expect to have a filter (not sure if it will be ceramic, fiber, etc.) somewhere between the tanks and the pump that will push the water into a bladder tank before it reaches the household pipes.
I know you can have solar panels on the roof, and I know you can harvest rainwater from the roof, but is there some health risk in harvesting rainwater that has fallen on solar panels (and the racks, cables, etc.)? Do I need to worry about any chemicals being leached into the water? If so, what would be the best way to filter them out? I plan to use this rainwater for drinking and cooking.
Note: I already plan to have a filter for things like bird droppings and other biomatter. My question is specifically about substances that could leach off the solar panels or any related hardware.
Pedro
  • 171
If you plan to use that collected water for drinking and cooking then you will need a proper filtration / treatment system... Ingesting diluted bird-droppings is not a good idea...
So, a simple filter may not be enough, you may well need UV treatment, but you should consult the authorities for the standards in your location you are legislated to meet and consult some just for your own health and others who may drink your water...
Solar Mike
  • 30,038
  • 69
No, it isn't, but not because of the solar panels.
If you have access to municipal water, there's no economically viable way to make rainwater potable. Roughly speaking, rainwater is about as dirty as "grey" waste water (from sinks, showers etc.) and it needs a similar amount of processing before (re)use. Rainwater contains all kinds of pollutants from the air plus whatever gets leached from your roof and gutters, so it's not really clean in any sense.
There are many possible uses for treated rainwater and grey waters, with each successive level having more stringent requirements (and thus being several times more expensive):
  • Garden, toilets: You only need to remove solid particles (tiny grains of sand and the like) to prevent clogging your toilet tank fill valve and to make sure the water's not too smelly (you don't want your toilet to smell worse after flushing than before, which is what happens if you use stale water). You just need to make sure you store the water in an underground tank (constant low temperature), don't store it for too long (2-3 weeks maximum) and use a simple filter.
  • Washing clothes: More filtering (carbon filter) needed to prevent clothes from getting discolored and really smelly.
  • Showers, baths, sinks: Need to eliminate bacteria and viruses. There will be lots of them in the tank and your shower will gladly disperse them into the air and you will be breathing them, with unpleasant results. You thus need UV treatment, ozone, or chlorination.
  • Drinking and cooking: You need to get rid of all kinds of dangerous metal ions, nitrates/nitrites, carcinogenic micrometer-sized dust particles, volatile organic compounds, chemicals leached from plastics and so on (this would also take care of whatever comes from the solar panels). This is a real technical challenge. Reverse osmosis or distillation is not an answer – it will remove all ions, making the water not potable. (Drinking distilled water will kill you pretty quickly.) Ion exchange columns won't remove small organic pollutants, and so on.
Given that water usage also usually decreases in this order, it usually makes sense to only do the first two levels. If you're in a really dry region where municipal water is extremely expensive or unreliable and/or you want your house to run super-green (even though it doesn't make sense economically), you can consider the third level (personal hygiene uses) as well. But making rainwater potable? Only if you really don't have any other source of water.
TooTea
  • 2,407
I have been living with drinking water collected from the roof for 30 years, 15 with solar panels. I haven't suffered from anything.
Solar panels are generally glass and aluminium. They are also sealed. If water was getting inside them for chemicals to leach, the panels wouldn't be working.
Really really cheap ones have plastic covers, which I would avoid.
However, I have always used multi stage, whole house filtering, 20 microns, 5 microns, 1 micron and carbon block and a UV sterilizer.
A decent carbon block is supposed to remove most large molecules.
I would suggest, if you are worried, get a under bench or over bench, filter, such as reverse osmosis.
  • 139,495
  • 149
  • 386
Rohit Gupta
  • 8,055
  • 38
I think you've overstated this. Many communities in rural areas live off rain water and enjoy good quality and clean water (without complaint). It's important to treat it (as your caveat makes clear) with UV for fecal contamination but I'm far from convinced that your statements around drinking water with regards to metal ion, nitrates and dust particles is true.
I'm always happy to be persuaded but can you cite any papers or references from credible sources where I could research further please?
