I would like to install a grab bar in my tiled shower. Do I need to find a stud or will wall anchors be enough?
Asked
Active
Viewed 2,989 times
Studs are best
There are anchors that are quite strong. But drywall is sometimes weaker than expected. This is a special concern for a grab bar because the force is not a static weight like a mirror.
If you can mount the bar to 2 studs with long screws then you're set. If not, I would mount a piece of wood to two studs. Paint or stain to match the decor. Mount the grab bar to the wood with screws.
- 139,495
- 14
- 149
- 386
