I need to cut some stiff sheet metal for roofing trim and the problem is dividing larger sheets. For example, I might have a sheet that is 6 feet x 12" and I need to divide it in half. The problem is that my snips cut a little ways into the sheet, but soon they get stuck and I can't push them in any farther.
A book I have on sheet metal says that one side of the cut is supposed to "curl" away as I cut, making room for the shears and I am supposed to cut so that side is the narrow "waste" half. But in my case I am dividing a wide sheet, so there is no "waste" strip, both sides are wide.
I can see that if I was just trimming off half an inch, then it would peel away, but when both sides are 2-3 feet wide, that doesn't happen. So, how do I divide the sheet?
Tyler Durden
  • 6,971
  • 66
  • 113
If you were doing a lot of freehand sheet metal work, I would recommend a nibbler (it takes little bites out of sheet metal) or set of powered shears with two cutting edges (they literally create a single thin strip of curled up waste material — my Milwaukee shears create a curled strip about 1/4” wide).
A band saw would be another option if you have one and it is large enough for the size of sheet metal strip you want.
A jig saw or sawzall with metal cutting blade and the sheet metal very well secured to an appropriate work surface might be the best diyer-friendly option if it is something you only need to do a couple of times and you already have one of those types of saws.
statueuphemism
  • 5,369
  • 65
