I am trying to widen the doorway to a room in a house that was build in 1905. the framing is 16 on center, however the lumber is wider than a standard 2x4. by about a 1/2 inch. (the actual dimensions of the wood are 2x4).
I can position the jackstuds so that they are flush with the wall of the room, but that would leave a gap on the other side.
How should I handle this? Should I rip a 2x6 to fit?
EDIT: the wall is load bearing
John Pfleger
You may have to rip a larger board, but you might be able to find "rough cut" lumber at some yards. I had a house built in 1910, I had the same problem. I was able to find rough cut lumber for interior framing work, but for anything exposed, I had to mill down larger boards.
JRaef
  • 15,146
  • 40
You either rip a 2x6 or you stagger frame 2x4s by butting them to one side then the other. If the wall isn't load bearing it doesn't really matter.
DMoore
  • 50,637
  • 93
  • 208
Frame with 2x4, add a filler strip. The filler strip to make walls flush or same thickness. Way cheaper than wasting a 2x6. You can not find #2 rated framing stock full 2 inch by 4 inch. Rough lumber does not have the #2 rating for frame work.Or if you can reuse some of the old lumber. Apply a new header .
They should make it, but they do not.
