I am interested in building a pond near my home in Maine. Unfortunately, water supply is limited, so I was curious to see if it would be possible to maintain a pond without having to manually refill it using well water. I found some resources suggesting the possibility of using rooftop collected rainwater for topping off a pond, but I wasn't sure if this would be sufficient, so I created a spreadsheet to determine feasibility.
The spreadsheet can be found here.
The results of this spreadsheet appear too optimistic for me to believe. Using average rainfall/evaporation data for my area, an assumption of 1 gallon leak per hour, and inputs for the dimensions of the roof and prospective pond, the water level seems to stay completely full without any intervention all year round.
Is this possible? Have I missed anything in my calculations? I'm thinking of using a rubber liner, but mostly I'm investigating if this is possible in any way first before looking at specifics.
How did you determine a leak rate ? Will it be concrete or rubber , or ? Will there be high edges to keep out roots and prevent capillary action of soil. My small pond in TX ( 800 gal) , rubber liner , leaks over a gallon an hour which I can't find. But one data point ; swimming pool in northern IL essentially stayed full from precipitation Oct to May ( no swimming/splashing ) ; being frozen significantly reduces evaporation which I think will work even better in Maine. Depending on the location and size , wildlife like deer may be a factor. Deer drink out of mine but it leaks so much I have no idea.
blacksmith37
  • 8,401
