19
As a competent DIY'er, am I legally allowed to install Hive myself?
The reason for the question is I have been asked to provide a cert as I'm selling the house.
If not, can someone point me in the direction of where it legally states I can.
chicks
  • 239
Alan
  • 191
In the vast majority of jurisdictions, most DIY work is perfectly legal in a house you own/land contract, and live in. The only exceptions are things like Freon handling, gas lines, and several other crafts, due to the particular hazards (often indirect, e.g. Freon).
You're not allowed to work on houses you don't own for obvious reasons. In many crafts, including electrical, you're not allowed (or permit non-licensed people) to work on houses you rent out, because that would be a huge incentive for "slumlord repairs". Given that rental properties tend to already be at the "more distressed" end of the housing spectrum, this is a recipe for dead tenants. However it is presumed you have incentive to do good work on housing you expect to occupy yourself.
Further, certain minor jobs are always allowed (for homeowners not tenants) due to their simplicity, common-ness, and low chance of critical failure. For instance changing receptacles and switches (typically done for cosmetic reasons) even though this work is harder than it seems. I would certainly expect that changing thermostats on a 24VDC system would be on the short list.
That said, the "only work on houses you expect to live in" principle applies in spades. If you are gussying up a house for sale, STOP. Aside from the "no incentive to do safe work" factor, you're also locking them into choices they may not want. Don't lay white carpets (pretty but nobody wants to live in it), don't fit 20-space stuffed service panels, and don't pick a smart 'stat for them. Give them a price concession of a fraction of the upgrade cost and let them choose.
17
The final answer will depend on your specific jurisdiction. However, generally speaking
  • Plumbing - gas and water - typically requires appropriate licensing and/or permits
  • Electrical - "mains" voltage or above - i.e., typically greater than some particular voltage, but generally designed to include 120V/240V (and above) but NOT to include telephone, network, doorbell, low-voltage thermostat, etc. - requires appropriate licensing and/or permits. Note that the "do your own electric work" really varies considerably - some locations forbid it unless you are licensed (possibly with a special "homeowner's license" available), some allow you do basic work yourself (the sensible answer, IMHO) but not big changes, and some allow you to do almost anything in your own home.
  • HVAC - in addition to gas, water & electrical issues, working with refrigerant (most air conditioners and heat pumps) requires special licensing
  • Changes to the outer structure of the house typically requires a building permit
In most places, this means:
  • You can't (legally) install or do major repairs on most HVAC systems, but you can replace a thermostat (low voltage, not directly working with gas or higher voltage electric, etc.). The exception is a line-voltage thermostat, but that's a Hive is a typical low-voltage thermostat.
The actual specifics will vary depending on location. But as a general rule, you should be OK replacing your thermostat yourself.
  • 139,495
  • 149
  • 386
