I've noticed some apartments that use both for water supply to faucets and toilet cisterns.
I understand that the braided hoses are rated for higher pressures, but how do they compare in terms of durability at typical static and dynamic pressures?
Is it correct to consider the EPDM layer in braided hoses, by itself (minus the support of the stainless steel braiding), to be equivalent to a rubber hose in terms of pressure resistance?
Trend2019
  • 81
The braided stainless steel flex supply lines are just jacketed with braided stainless. The jacket is there for appearance and perhaps resistance to incidental contact damage, but has nothing to do with the pressure rating.
In general, rubber hose is not used for faucets and cisterns; the hoses (whether jacketed with braided stainless or not) are commonly reinforced PVC (at least in my area, anyway). The washers are often EDPM rubber...
Jimmy Fix-it
  • 37,916
  • 35
  • 62
