I live in a trailer and am debating attempting to put a hose outside/on the side.
A few considerations:
  • I have no plumbing experience
  • It gets -40 where I live in the Winter
I have read great things about PEX & "Push Connectors" which made me think I can tackle the project, but my main concern is the spigot near ground.
I plan on shutting off the water each winter just FYI.
Question:
  • Is it safe to put the drain-cock spigot connector near ground? I'm talking within 6"
  • I was concerned with "akwardness" as well and wondered about installing the spigot upside down so the connector is facing upwards. Does anybody see any issues with that?
Drain Cock w/ Spigot
Similar DIY Post:
options-for-replacing-an-at-grade-hose-bibb
Here is my shopping list so far if you see any issues:
The only thing left is for me to look at the setup downstairs and figure out how I can "T" off of it.
[Update]
This is in a mobile home park.
Thought I'd share what I ended up doing. I tore out all the copper pipe "main line" and replaced with plastic pipe. I added a "T" and then installed an 18" frost free silcock basically at grade. I added heat-tape and insulation on the inside, now I'm just debating on if I need to cover the valve in the winter (perhaps with a simple box?). I don't usually do what I did above (post multiple questions), so I created a new thread with that simple question --> Frost Free Silcock - At Grade - Problem in Winter?. I'm also debating on not shutting off the water on the inside (I did install a Ball Valve with a drain right by the "T"), but worry about heat tape on an empty pipe. Thinking about it, I doubt that would be an issue as CPVC is rated like 200F, but the point of posting the question was to get feedback :).
In regards to the "awkard angle". I will be digging out a bit under the bib to allow for the hose attachment and having it at the "proper" angle.
Thanks for all the tips!
